Re: aluminum as floor material?
I agree an aluminum deck would be nice, but unless the rest of my boat is also metal I wouldn't bother.
Sure, it won't rot even if abused, but it can have other problems, and as has been mentioned it can create/add to noise and it's uncomfortable to kneel on.
You don't need quarter inch plate to make an aluminum deck, although it would be more expensive than plywood. I'd personally use something like 1/8" tread plate with an appropriate support structure of something like 1 1/2 inch rectangular tubing or channels welded together and lag bolted to the wooden bits of the boat.
It could be made to be lighter than the composite decking made from plywood and glass, and stronger, but if you really need light and strong go for thin foam or marine ply decking with carbon composite covering.
Attaching the aluminum to the hull sides would be a problem... you'd have to put in a wood cleat along the edges and screw/rivet the aluminum to it, and it still wouldn't be as strong as a glassed joint. Plus there would be hard spots and fiberglass failures anywhere there's stress because the aluminum would be very stiff and the fiberglass would flex around it.
If you must have a deck that won't rot, make one out of foam core and fiberglass.
Erik
