Engine removal help
Status
Not open for further replies.
AnthonyY
Re: Engine removal help
It is a omc manual(Ebay for about 60 dollars). do I have some other version than what everyone else is using?
AnthonyY
it is in section 17 of the manual, page 6, 9, and 11 of the section.
Bt Doctur
It may be a OMC manual ,but for what type of drive?? You did read that 6 nuts were removed.
Stringer or Cobra.
Bt Doctur
Anthony, If that is the way you did yours, I would pull the drive to check the engine alignment witch is critical to long coupler life.If not , you`ll be pulling the motor the correct way to replace the coupler
bigbroncoxlt
Just because it CAN be done, doesn't mean it SHOULD be done that way.
Status
