I just got a 50hp johnson from 1980. The engine was runnning when I got it but not very good, got soaked after a while and difficult to start again. I cleaned the carbs and replaced the sparks, resulting in better performance but still running like a bad och trash after about 5min.
So my next guess is that I have bad sparks since the engine is running bad on idle and can't rew hard when it's in gear.
The previous owner told me the he had some problems with the overheat alarm so I replaced the impeller and flushed the system, however, the heat sensor in the engine top looks pretty bad, the wire is half visible but I don't get the alarm when I ground it. Could this have anything to do with problem? Please give me some input where to start, my big issue is that the motor is mounted on a boat sitting in the water making it all more difficult to work with.
