New to Boating
Shawn73
I am starting to have an interest in purchasing a boat. I have never owned a boat or been around boating. I have been doing some reading and decided a bowrider is the best fit for me. An i/o makes me feel more comfortable because I am a car guy and would feel more comfortable with a motor I felt like I could work on.
I want to spend less than $7500 but I would be more comfortable with a $5000 purchase price because it is my first boat. It will mostly be used for tubing, skiing, etc.
What brands are going to fit my beginning needs the best? I know maintenance plays a key roll, but do any brands seem more reliable than others?
This might seem like a pretty open ended question but I just need a little help on a starting point for my own research.
Thanks.
IVAZ
Re: New to Boating
Welcome to iboats.
Boat brand is not as important as engine and drive. Get one that has a Mercruiser or Volvo Penta drive. Try to avoid the engines that are Ford as they are not as common and cost more to keep running(most boats come with Chevy engines). Stay away from the Mercruiser 470, its also not as common and temperamental according to some. The OMC powered boats should also be avoided as they are also no longer in business.
On the boat itself you need to really check the deck (floor) and transom for any signs of rot. Any soft spots on the deck will require work to the stringers most likely and end up costing much money and time to repair. The drive has some rubber hoses that connect it to the transom, they also need to be inspected.
For $5000 you should be able to buy a boat in good shape, don?t accept one that requires work.
Others will chime in and give you more detail and things to look for.
Good luck.
ThePostMan
Re: New to Boating
Something to keep in mind. . .and this is just my personal rule of thumb, others may have a different take:
When buying a used boat, consider budgeting somewhere in the neighborhood of 20% over the actual purchase price for miscellaneous expenses. No used boat is going to be exactly the way you want it, and you may find yourself buying stuff. Things as simple as new bumpers, PFDs, and beach towels that match your boat will cost hundreds of dollars.
So, keep a cash reserve. Best advice I can give!
WTR4FUN
Re: New to Boating
It wouldnt hurt to spend some time at a local boat launch to see how to launch and not to launch. Talk to some friendly people and learn some ettiquette. It can also give you a chance to look at different boats and get a feel for what you want if you have not decided yet. My advise is be patient and look for the one that was well maintained.Also buying from a private owner may get you more accessories with the boat, mine came with a tube and 2 pairs of water ski's and 2 props.
rjlipscomb
Re: New to Boating
Do you live near a marina that rents boats?
May help to take one for a spin and get an idea the various models and uses available.
Hanging out at the boat ramp and asking questions is a great suggestion.
