Need help with a basic!!
CZim
Just bought our first family boat with a Mercury ELPTO 75. Bought it used and without an owners manual. For the life of me I can't figure out how to check the oil level. Don't see any oil level side gauges and when I open the square compartment to pour the oil into, there is an additional hole that looks like a dip stick might fit there???? No clue - currently the a warning alarm goes off and I add oil. Also, when reading other forums, if I'm at full throttle and only pulling 4k rpm, is my prop too large? Thanks
verado7
Re: Need help with a basic!!
need engine year or serial #
boat length ,weight,construction,and hull type ie:v-hull, boat make and model would also help.
in the meantime i wouldn't risk blowing the motor until the problem is fixed .
post back and we will try to help you .
