Pontoonhorn
- Joined
- Jun 9, 2009
- 7
I'm trying to rewire my mom's boat and everything is just about complete but I can't find the Tach wire running from the engine to the tachometer..
There is grey wire comming off the back of the tach gauge (S) connection but it been cut like many of the other wires.... But is missing from there to the engine..
Could it be running with/inside the control/ignition wire harness...?
Or do they normaly run by their self routed outside but along with the control wire harness from the motor to the console?
I looked and there is no wire coming from the motor but the control/starter wires ect..
I know it's suppose to be grey... But the color code was long since screwed up on this boat but I've got everything else figured out... fuel sender.. Water pressure ect...
Now the tach has no apparent sender wire from motor...?
I'm no boat motor tech but is there anywhere I should look on the engine to find a missing sender wire...
I think it could have been disconected and or cut unless it inside the ignition harness???
Is it hard to find the tach wire output connection on the motor so that I can replace it a run a new wire to the tach?..
Or from what I've read, find the wire or connection point from the rectifier on the motor... so I can run a new wire
Thanks in advance for any help.....
