(By the way, I got all the specs on the bearings and then found the correct cross referance and bought them at my local bearing house from the same manufacture. MUCH CHEAPER!!)
Now I am still trying to figure out how the heck oil is pumped to these bearings and gears. When I took it apart the bearings and gears had oil on them but there wasn't any oil to speak of in the upper case so I am assuming it gets pumped to them from the lower case and drains back down with gravity. I don't want to miss something and end up with no oil getting to these bearings and gears.
I don't think the oil level is that high but who knows. Bottom line seems to be it wasn't me and blindness, there is no pump. You think that shocked me, I was even more shocked to see there is no raw water pump in it!
(Hey Don, I was in Ketchikan on MON. It hasn't changed much!)
Don can correct me if I'm wrong but I think all the SX's had engine driven raw pumps.
Green with envy ............... I miss it!!!![]()
ALL Volvo engines used engine driven raw water pumps. None of the drive have ever had pumps in them.
