FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
When i turn the motor over, prop spins and motor will not start. The "pull up to start" lever on control box does not fix problem, in fact, the motor will not turn over at all with it engaged. What gives?
I have a 71 60hp motor and I suspect it is probably identical to yours.
When you pull up on the warm-up lever it moves the throttle cable which is activating the safety switch. According to my manual, it should turn over in gear at low throttle. Your safety switch is probably out of adjustment. I'm having that issue with my motor now, it stopped cranking over and I've traced it back to the safety switch circuit. I've not pulled the flywheel yet so I'm not sure if it's bad or just out of adjustment.
The safety switch is just doing it's job, which is to prevent starting above a certain throttle setting. A screw in the control limits how far you can move that lever. That is what is out of adjustment. You can see/adjust it down through the slot by the lever.
However, why the motor won't start and run is a different and unrelated problem.
