frustratedboater
- Joined
- Jul 10, 2007
- 499
Since rebuilding my marine 600 holley 4bl, it needs the choke slighty closed in order to run. Carb was dirty inside and cleaned very well (I think). I was very maticulus going through making sure the floats were level, all ports weren't clogged, etc. There is a red plastic cam-like lever which I switched to ride on the top of the choke rod near the clip. I think tha's correct. Either way, it still ran just like before.
Timing on the boat is around 8-9 degrees BTDC. Any suggestions as to where I should be looking?
