k_kindig11
Thread starter- Joined
- Jun 10, 2009
- 2
I've got a 1974 Johnson 9.9hp outboard that has been running a little erratically so I took the carb off to inspect the float bowl. Well, since the float bowl is metal, the inside has a significant amount of rust in it. The cork floats are also covered with junk. Rather than buying all new parts for it, I thought about just buying a whole new carbureter that's clean and swap it out. I found a carb from a 1991 15hp johnson but didnt know for sure if it would be a direct replacement. This carb has a plastic float bowl and plastic top where as mine doesn't. Anyone know if it will work, and if there would be any potential problems with using this carb on my motor?
