Mercruiser Twin 5.7L EFI Service Manual?
mszjessy
hello!
So i'm still looking for the manual. I was directed to the Adults Only section but it's all gibberish to me :( I'm not sure which one i should download. I downloaded Manual #17 but i'm not sure if thats the one i need. I got some information on the engine so can someone please tell me which one it is that i should download?! I would greatly appreciate it!
The details are:
2000 Mercruiser Twin 5.7L EFI v8.
I have 2 serial#'s for it and they are:
OL656235/OL656260
QC
Re: Mercruiser Twin 5.7L EFI Service Manual?
Are you looking for the Operators Manual or the Service Manual? If it is the Service Manual, I think you need #24. What's Gibberish?
mszjessy
i'm looking for the service manual. thanks i'll check out #24!
mszjessy
I'm sorry to keep bothering but do you know if theres a difference between EFI and CID?
QC
EFI = Electronic Fuel Injection CID = Cubic Inch Displacement . . .
mszjessy
hm.. ok i have no idea what that means but do you think that manual would also work for me?
thanks so much for helping me
Don S
Manual #24 is the manual you need for those engines. If you are having problems understanding EFI and CID, you are going to have fun with some of the other abbreviations used in the manual and on the engine.
in. hg -- Inches Of Mercury
BARO -- Barometric Pressure
BAT -- Battery Positive Terminal, Battery or System Voltage
B+ -- Battery Positive
CKT -- Circuit
CONN -- Connector
CYL -- Cylinder
DEG -- Degrees
DIAG -- Diagnostic
DIST -- Distributor
DLC -- Data Link Connector
DTC -- Diagnostic Trouble Code
DVOM -- Digital Volt Ohm Meter
ECM -- Engine Control Module
ECT -- Engine Coolant Temperature
EEPROM -- Electronic Erasable Programmable Read Only Memory
HEI --High Energy Ignition
EMI -- Electromagnetic Interference
ENG -- Engine
GND -- Ground
GPH --Gallons Per Hour
IAC -- Idle Air Control
IAT -- Intake Air Temperature
IC -- Ignition Control
IGN -- Ignition
INJ -- Injection
kPa -- Kilopascal
KS -- Knock Sensor System
KV -- Kilovolts
MAP -- Manifold Absolute Pressure
MIL -- Malfunction Indicator Lamp
mSec -- Millisecond
N/C -- Normally Closed
N/O Normally Open
PROM -- Programmable Read Only Memory
RAM -- Random Access Memory
REF HI -- Reference High
REF LO -- Reference Low
ROM -- Read Only Memory
SLV -- Slave
SW -- Switch
TACH -- Tachometer
TERM -- Terminal
TP -- Throttle Position
V -- Volts
VAC -- Vacuum
WOT -- Wide Open Throttle
mszjessy
hehe! thanks so much for all ur help!
i'm looking for the manual for my boss . i dont know why he makes me search for information on stuff i know nothing about :(
Ayuh,... Just give the Boss the address for iboats.com,+ tell 'em it's All here....;)
QC
Sorry Mrs. Jessy, I think we now get it . . . I guess we need to consider that the poster is not always the repairer or operator or owner . . . :)
Don S
LOL, I was just thinking about what happend when something was actually wrong and how YOU was going to be able to deal with it. :eek:
Now I understand ;) ;)
