I have a 2000 Evinrude 90hp 4 stroke or my pontoon. I get out on the water and run around 30min any speed I want and the boat performs flawlessly. Then suddenly I lose power if I am running above 3000 RPM. The boat losses the comes back and losses again. Naturally you drop the throttle back down to a low RPM like 2000. The boat will run just fine from there so long as I do not go over 3000 RPM. Once I try to go faster I run into the same problem...sudden loss of power. If I drop the anchor and sit for about 30mins with the engine off and start back up. I am good again for another 15 to 30 mins running as fast as I want. Then that's about it goes back to losing power and I cannot run over 3000 RPM. The boat has been at the Marina for 3 weeks now. They've replaced the fuel lines checked the separator and that still did not fix the problem. Now I am getting the run around.
Based upon what I have read so far would any agree that they think it is the power pack? Does anyone have any other ideas.
