I think its a 1968 40hp super seahorse/super quiet
shawpdx1
model#j241968
there is 2 copper female outlets on the cooling cover one goes to the rich lean control looks like 1/4 inch metal tube and the other has nothing in it can I just plug this hole? also it's electric start with a 3 way toggle switch I think they used it for the starter it push up and let go it goes back to center puch down I guess this would be shut down how would a guy wire this to the starter I have a book on it dosent show any awnsers to this stuff
thanks in advance Ted
crxess
Re: I think its a 1968 40hp super seahorse/super quiet
Don't know about the copper tube.
On the switch, first you need to use an ohm meter to sort out who it functions.
Test contacts in each position to verify which is active in each position.
May be down=no power
middle=power(constant)
Up=power (momentary)
May feed charging system + start
F_R
The tube and fitting are for the hot-air heated automatic choke. Air flows in through the open hole, through a heat exchanger inside, and out through the tube to the choke housing, then into the intake manifold. DO NOT plug it up. If it is defective, fix it. If the heat exchanger is burned through, it will suck exhaust through the choke tube and make it run terrible. If you plug the hole, it will not get the air that should be going through it, which will upset the fuel/air mixture and make it run lousy. Not to mention that the choke won't work.
I have no idea what some genius has cobbled up with the 3-way switch. But I do know that there is supposed to be a spring loaded on-off toggle switch for the electric choke. Yes, there is an electric choke in addition to the hot-air choke.
The book is probably right, if it is the right book. If the wrong book, well.....
shawpdx1
thanks. are these good motors? or a headache? guess I will make a new tube for it its just missing no Idea why bought it that way its a nice looking motor alot of chrome nuts on the leg must of been a caddilac for its time?
tx1961whaler
Great motors, especially if a manual shift. I have not used the heat exchanger tube for years. I'm not totally convinced that it worked real well when new. Mine only need choking for about 10 secs when first started, so I just do it with the switch.
shawpdx1
yes its a manual shift not the push button whats it worth runnning?
shawpdx1
need to figure out were that other tube went to thats missing
shawpdx1
this must be a coil point ingintion system
shawpdx1
looked this motor over real well for the life of me can't see were that missing lower tube went anyone know?
tx1961whaler
F_R answered the question. It went to the choke on the carb. The other opening is left open. It is possible that someone removed the automatic choke on the carb, or even replaced the carb
shawpdx1
well good deal then Im not missing anything the otherone runs to the lean control knob just looked like with a threaded hole there something went there thanks Laugh I guess he did I missed that
shawpdx1
can I run this motor 50:1?
coolguy147
yes but if ur first time running it in a long time may suggest to add more oil more doesnt hurt just when u have none or not enough it burns up the whole thing
did anybody mention changing impeller and checking compression?
