krisnowicki
- Joined
- Jul 11, 2007
- 1,172
SO I bought the boat knowing it was a project. I got a kicker and electronics worth more then the what I paid. So here is the question.
#1 cylinder on the 125b is 0 compression (warm or cold) I would guess a stuck valve. #4 has 100psi #2,3 165-170. SO the motor is garbage.
Moving on. from what i understand parts for the 131 are expensive. so here is my plan tell me if it will work.
I get a 290 drive including transom housing will this fit in the cut out for the 270? If i Just wanted to put the 290 drive on the 270 transome would it fit does it use the same transom unit?
The 290 drive comes with a bellhousing and everything for the v8 305 or 350. So I buy a SBC put the bellhousing on it and the 290 drive.
Issue I can forsee maybe you can help:
The boat does not have power steering It has a tiller arm like you see with out boards. does this make the conversion not possible?
That tiller arm may rub v8?
If this isn't going to work what other engines are available that will work with the 125b setup? 121? 131 135 145? Any striaght sixes?
The engine room compartment would hold a 454... Also, the stringers are in place for a v8 already.
