jgresham75
Thread starter- Joined
- Aug 19, 2008
- 70
Bought a new boat, previous owner included what appeared to be an unused 3-blade 21 pitch SS prop. Put prop on and did not rotate straight. Took it to prop shop and he said hub was off center and said he could re-hub. When I went back he told me he tried two hub and couldn't get it straight.
Here is where I need the help. He did put a new hub in but said it was not straight but what he said he could do is adjust the pitch on the blade to be center to the hub (meaning the center line where the shaft goes in). Is that a good idea?
That would mean that the blades would rotate evenly around the shaft but the outer hub of the prop would not rotate centraly. I hope I am explaining myself correctly. That would mean that the next time it was rehubbed, the blades MAY have to be adjusted again.
This shop is a prop shop so he SHOULD know what he is doing. The engine is 5.7 Volvo and top speed would be around 45-50 at 4500 rpm. Please help. Thank you ahead of time.
