sleddogs13
Thread starter- Joined
- Jun 11, 2009
- 20
Bogged down late last year to 2 or 3 miles per hour. We had used the boat a few months and it ran good. Replaced power pack, coils, rebuilt carbs. Did not find high speed jet.The carb diagram on the shop.evinrude parts website does not note a high speed jet just a slow speed one. Found the low speed jet. It appears this carb just has two screws in the front one high on the carb and one on the bottom bowl in the front of the carb. They do not adjust just screw in.
Started right up. Went to give it a little throttle and it would just bog down and die. Spark plugs are wet. Idles up fine. Cannnot pull wires to check for engine change because it never or rarely get up to high speed. Only a few times it took off at half speed. Then it bogs down big time! How can we check for spark. The power pack is aftermarket CDI and Coils to. Fuel tank lines are all new and carb hoses to. Bulb on fuel tank is hard when engine runs and gas is new. After spending all this time and money it runs just like the end of last year if not a little worse. Any help would be great!
