davis073005
Thread starter- Joined
- Jun 13, 2009
- 3
I have a 1973 evinrude 115 it leaks a slow but steady oil/gas mix through the vent in the bottom of the air cleaner housing when running at idle in a tank i dont know if this is a problem or normal for these old engines it builds up on the spill plate below the carbs it also has a problem whem I put it in gear it dies somtimes if Im not quick enough is this all normal any help would be greatly appreciated thank you
