terankinjr
Thread starter- Joined
- Oct 27, 2008
- 15
Hey Guys... got a question, and I hope this is a simple fix but here goes..
My Boat stats:
Year: 1977
Make: Classic Industries
Model: ??
Boat Type: Cuddy Cabin
Engine: 188HP Mercruiser 8cyl
Cooling Type: Raw Water
Drive style: I/O
Drive Make: Appears to be Mercruiser as well
Owned the boat > 1 year
The problem: Took the boat out about 1 week ago and I noticed that I wasn't getting to normal speed... I didn't think too much about it because I recently (the day before) found the anode on the cavitation plate was angled in the wrong direction, I replaced it and corrected the angle (it was also terribly corroded) and I assumed I was getting inaccurate readings from the speedo because of the hard pull to port... that day I almost got stuck in some muck in a VERY shallow area so I had to "power" my way though it. All seemed fine bringing it back to my slip... so fast forward to today....
I get out on the boat... idle's fine... slow speed fine... I throttle up, planes ok... and once I get to WOT, I find I lost even more speed off my top end and the RPMs seem unstable... engine sounds like its intermittently chugging... so I bring it it in and start talking to the guys at the Marina... they give me some ideas and I get to working on the problem... I pulled the prop, looks ok, not bent, and seems to be same since I dropped the boat in earlier this season. I try a new prop to test and add some dry gass and fill the tank (I was low and figured this might be a "bad gas" situation.... I take the boat back out... it chugs once... then seems ok, I get some speed back (not all of it) but the boat just doesn't sound right... I keep on going, then I turn the boat around at speed to head back... the engine begins to intermittently chug again (but only when I turn it seems)... I check the RPMs and I am around 3500 to 3700.... I back the throttle down to neutral and check the engine to see if it is making any odd sounds at idle, sounds normal to me... I throttle back up... I now get 4100 to 4300 RPMs... throttle down again to neutral then back up... I'm at 3500 to 3700... and I notice kind of a "wooshing" noise coming from the engine, I never noticed it before but before today I was not listening to the engine for problems. I get back in to my slip and put the original prop back on and talk to the guys at the Marina. They start talking about doing a tune up, I am not sure when the last one was done on the boat I have only owned it for about 9 months, (also my first boat) I did all the winterization stuff except for the tune up items...(I was under the assumption that the tune up was done last year and that one only needs to be done every 2 years) which I know to be; cap, rotor, condenser, points, plugs, fuel/water separator and to replace/clean the flame arrestor, but I will probably have someone else do this because, I have no clue what points are or where the condenser is...
Any Ideas on what might be causing this problem? or do you think a tune up would cure this issue? ( I will do one anyway just so I know when it was done). I hope this will be a cheap/easy fix cuz they cut hours at work and I am a little low on cash and the Boat is what I use to get away from it all...
Well I'm rambling... its late and Im exhausted....
Thank you for your continued expertise and assistance...
Regards,
Tom
My Boat stats:
Year: 1977
Model: ??
Drive style: I/O
Regards,
Tom
