Mercruiser 470 locked up
Grady79
I have a 470 that won't crank and I'm at a loss. I pulled the plugs and tried to crank it and nothing. I put a breaker bar on the crank and it won't even budge. I poured trans fluid into the cylinders and left it sit for about two weeks and still nothing. I'm not sure what else to do. Any help I could get would be great. Thanks in advance.
Trevor
Bt Doctur
Re: Mercruiser 470 locked up
Is there anything elese we should know on how, why it got locked up.
ran hot
no oil
drive oil missing /lost
severe impact history
etc,etc,etc.
cooter2506
Remove the outdrive and see if you acn spin engine. That will tell you if it is the outdrive or engine
Grady79
Unfortunately I don't know the history on the boat or the motor. I bought it a couple of weeks ago (not running). I found another 470 but I don't want to purchase it until I find out why this one is seized.
Bt Doctur
control box in full fwd, remove rams and 6 mounting nuts and pull drive to isolate the problem
Don S
Pull the drive, it may not be the engine.
Don S
One other possibility, pull the front pulley off the crankshaft. If the magnets came loose and got wedged in there it would lock the engine up.
Grady79
Ok going to try all that now. will be back in an hour or so thanks.
Grady79
Got the outdrive off. Tried turning the engine with a breaker bar and it won't budge.
Grady79
Took the valve cover off and it looks brand new in there. not a lick of dirty oil.
Don S
Bt Doctur
remove the spark plugs and probe with a wooden dowel, wet or rusty would indicate trouble
Grady79
I'll have to try probing the cylinders once I figure out how to get the crank pulley off. I think I'll just end up pulling the head to see what they look like. Worst comes to worst I'll buy that other 470 on tuesday. I just want to find out why it won't turn. It wouldn't be the starter stuck against the fly wheel would it?
45Auto
Most likely scenario is a piston rusted into a cylinder by a leaking head gasket or a leaking riser/manifold while it sat up for a while. Not a long enough breaker bar in the world to overcome that situation. Lots of times you'll have to break the piston to get it to come out.
Good Luck!
Probably worth your while to look into replacing the manifolds and riser if you're going to the trouble of replacing the engine.
Grady79
Good Luck!
That's what I was thinking as well, but at least if that's the case it makes me a little more happy that it was just neglect and not some faulty aspect of the engine.
Grady79
Piston rusted fast to the cylinder wall. Pulled the head only to find about a 1/4 inch of rust on the cylinder wall.
