Volvo SX out drive won't go all the way down
brianc03
I have a 1999 Regal with 4.3 V-6 and the outdrive will go up and down fine, except when it gets about1 inch from all the way down and it just stops. I can wait and hit the switch again and it will move just a little. I continue this over several times and it finally gets all the way down. It does this with both the throttle and trailor switch. Any ideas?
Don S
Re: Volvo SX out drive won't go all the way down
Take the cap off the trim pump reserevoir and see if there is a red plug under it. If there is, remove it and see if it works.
Phantom_II
Just out of curiosity, what's the story about the red plug?
Don S
It's a shipping plug to keep fluid from leaking out. Should have been removed when it was installed in the boat.
brianc03
No red plug.
Don S
Leave the cap off and try it.
Don S
What's the full model number of your engine? Need all the letters after the 4.3.
Do you have the black box on the transom with the flashing lights?
