1990 Bayliner Capri - what size to push it
mperu99
This is not really a engine trouble or repair question but then it could be..
What is the smallest engines size that a 1990 Bayliner capri could be used and still have fun..??
crb478
Re: 1990 Bayliner Capri - what size to push it
How long is the boat and how much does it weigh? If it is one in the 17-19 foot range I would not go smaler than about an 85hp motor. Also what is it rated for? You will be happier with as big as you can get.
jkust
You didn't say what size boat or the weight but for reference one of our boats is a 16 foot 1984 Capri open bow. It has an 85 horse Force and goes a legitimate 43mph with aluminum ski prop with 2 people aboard. 43 mph in a boat that weighs only 1000 lbs and turns on a dime is fun in my book plus it can pull any size experienced slalomer with a deep-water start or multipler knee boarders. The funnest part is that it hits top speed 2x as fast as my I/O so at least out of the hole it can beat much more expensive/higher power I/O boats for a good distance. If you have the larger Capri I would opt for the 125HP which I think was the standard outboard option.
mperu99
Im sorry ... its a 19' max HP load is 150HP however i am having a hard time finding a large engine.. but alot of smaller ones.. 70s and 80's
A.R.K.
You probably want a 115+ for that boat. 70-80 Hp is a bit small. They'd push it, but I guess it depends on what your definition of "fun" is though.
ezmobee
I responded to your other thread with the same question. FYI, the mods on here get cranky about double posts....
mperu99
sorry wasnt sure which one to post it in...
thanks..
