Bear700
- Joined
- Jun 6, 2009
- 12
I have a 1979 55HP Johnson. I got the boat about 1 month ago. It did run, however, I believe it was only firing on one cylinder at the time. On occasion, the other cylinder would "wake up". I just rebuilt both carbs, and put new coil and wire kits on both cylinders. When I pulled the boat out and started advancing the throttle, everything seemed great. Boat got up on plane, and we were on out way. Well, about after 1 or 2 minutes, the boat started to surge, almost as if someone were revving a motor at a stop light. Just a slow rythmic rev. I backed off the throttle....long story short....if I come way back on the throttle, the boat will eventually even out, when I get back on the gas though, the same rythmic pulsing begins. I thinks that there must be a fuel issue somewhere....did I get the floats wrong? I checked the pickup line...no debris. Checked the fuel pump....screen seems clear....any help here would be welcome!
