An old girl
Sonoran Heat
78 140 hp - need to prime carb with a bit of gas at every cold start. Start right up no problem when warm. Any ideas what might be causing this?
danond
Re: An old girl
I guess I'm of the mindset that if the carb has a bad component, it's probably due for a rebuild. Kits are cheap, it takes less than an hour or two, and the peace of mind is worth it.
They're not supposed to run forever. Seals go bad, pumps go bad, passages get blocked. It's unavoidable!
Sonoran Heat
Re: An old girl
Had carb rebuilt about a month ago, and a new mechanical fuel pump put on also.
