Re: 78 Merc 850 Cold Start Problem
Hi Corm,
Believe I found the hose, it was behind the starter, on the starboard side as you would be sitting in the boat. Looks to be in good shape, pulled plugs and put new one in, old ones came out wet, boat was sitting for a week. Going to back down the mixture and check after I get back. Going to test now.
Brian G
No, it goes from the bottom of your crankcase to the top of it on the starboard side of the motor. It is a little thin black hose. It allows unburnt oil that pools in the bottom bearing end cap to be pumped up to you top bearing
for lube and burning. It breaks from age & oil causing a lean condition in the motor.
Hi Corm,
Brian G
