68 Johnson 55HP - Starter Pinion Will Not Stay Engaged with Flywheel
hulvdog
As the title says, I tried starting the motor today, starter spins up nicely. Pinion gear ramps up to enagage the flywheel, then immediately drops out without rotating the flywheel (starter still spins).
If I manually place the pinion gear in mesh with the flywheel, then do a start, the flywheel rotates and the engine starts.
What is causing the pinion gear to fall before it fully engages with the flywheel, and do an engine start?
Joe Reeves
Re: 68 Johnson 55HP - Starter Pinion Will Not Stay Engaged with Flywheel
Inspect the flywheel teeth, the underside portion of the teeth. a worn bendix gear will (in time) cause the bottom area of the flywheel teeth to wear.
A new bendix gear cures this problem sometimes, if the flywheel teeth aren't worn too bad.
rbj
Make sure you have good, clean connections on you battery cables. A weak battery or bad connections can cause this problem.
