I'm having wiring issues with my '71 50hp. I picked it up for free because it was binding when turning over. Of course no start. Upon inspection, it turned out to be a fried lower crank bearing. Powerhead rebuild is done. Engine starts, and runs great (in forward). I've read ALOT of posts about the voltage to the solenoids, and I understand that 12v green is nuetral, 12v both green & blue is reverse, and no power is forward. My problem is that the two wires coming up from the lower unit are not connected to anything at the powerhead terminals or harness, and they are black! Whoever did the troubleshooting prior to me, must have dropped the lower for inspection, and disconnected the wires. I've had the lower unit off (impeller replacement), and it's obvious that the wires have been spliced. They are encased in some type of redish silicone. That makes it hard to trace which wire is which. I tried your advice of energizing the wires from the starter solenoid to determine if they are working, and I think I can hear a faint clicking each time. I haven't tried that yet with the engine running. From the info I got about the engine, it was shifting with no problems before the powerhead failure. The lower unit lube appeared fine as well. My question is where do these two wires connect to in order to recieve their power signal? I'm a new member to this forum, just joined tonight.
