slydog75
- Joined
- Jun 15, 2009
- 90
Well, I just bought my first boat and THEN I found this site. I probably should have done that the other way around, but hopefully I've made a good choice. I picked up a 19' 1987 Wellcraft Classic 190. It's in very good shape appearance wise, especially the upholstery for an older boat. It has a 165hp Mercruiser 3.7L 4 cylinder engine (this thing must have some massive clyinders to get 3.7Ls with only 4 cylinders). There seems to be a problem with the trim switch that I'll have to figure out more details on and fix promptly but otherwise electronics wise it's in fine condition. Any comments on this boat/engine would be appreciated.
Apparently this boat has a somewhat rare cooling system in that the lake/river/ocean water never enters the block. instead it has a closed cooling system that then runs through a sort of radiator that is then cooled by the lake/river/ocean water. The closed cooling side of this system has a small leak in it and the previous owner says he usually has to add a half gallon of water/coolant to it when he goes out. We plan on changing all the gaskets to see if we can fix this but, unless it gets worse, not until the end of this season (I live in Pa). Any comments on this cooling system and/or our plan to run it with the small leak for this season would be appreciated.
We plan on using this for a bit of everything; light fishing, water skiing/tubing/kneeboarding, and just runninng up the river to Pittsburgh for some boat tailgating at Steelers games.
