BuzzStPoint
Thread starter- Joined
- May 27, 2009
- 1,003
I picked up a 62 Glastron Skiflite not too long ago.
The plywood someone put down for the floor is warped and rotten. Plus she's ugly... This past weekend I started to sand the upper portion of the boat. Wonderful time sanding off the Latex House paint. But I have a few area I need to fiber glass. One being where the rear light pole attaches. I looks like someone was using that as a handle and broke the fiberglass. Shouldn't be too hard.
As I was pulling off soem of the side trim to sand, I pulled all the trim off the rear of the boat. To my suprise, You can pull back the lower shell and see the transom. The wood inside there is rotten. I dug in there with a screwdriver and puled a bunch out and it's water logged.
Question is, It looks like the upper portion of the boat is held inplace by the trim. Can I just remove the trim, lift the upper shell and dig out the bad transom? Or am I going to have to cut the rear of the boat?
