2003 envinrude 135 hp no oil light
william88
no oil light came on and cut my rpm to idle. tank is half way thier is no sending unit inside tank. help
Re: 2003 envinrude 135 hp no oil light
No Oil alarm is an indication that the OMS pump is not seeing movement of the oil into the gas line. You need to run premix until you sort this out.
I would pick up an OEM Service manual. Marineengine.com sells them as do other places. Have your model number handy. There is a troubleshooting procedure to test the OMS pump and the no oil sensor and wiring.
This alarm is as serious as it gets. If it is not a false alarm, your engine is running w/o oil, which will cause greate damage.
william88
Added oil when I got home and added oil light went off. It seems if problem is intermitent
