3M Fast Cure 4200 - What it says on the package...
Mark42
Ever actually read the package? This little bit surprised me from the 3 oz tube package:
Once opened, contents will begin to cure even if cap is replaced. Use all material within 48 hours.
Holy Cow! An $8.00 tube of sealant shot once opened?
Compare that to Boat Life Boat Seal. Still have a tube that is from 2003 and it hasn't hardened yet.
redfury
Re: 3M Fast Cure 4200 - What it says on the package...
Just shows you how aggressive it is and why it's worth the money you pay for it.
WizeOne
Balderdash! I have a tube of 4200 that is well over a year old, come to think of it, over two years old. Just used some of it yesteday to fix a broken portable phone antenna cover. I did have to use a drill bit to get down thru the hardened stuff, but once done, the stuff squeezed out of the tube like normal.
It's just been sitting on my workbench and I have used it numerous times after picking out the hardened top of the tube.
Moody Blue
I have had a tube of it (fast cure 4200) open for about 3 weeks now. As with silicone, I always fill the nozzle before storing. The contents of the nozzle hardens but the material in the tube stays uncured.
I wish I could find the $8 tube. It costs me $14 :eek:
Mark42
Thanks for the experiences guys. I hate to see money wasted. I like 3m products, and it just struck me odd that the tube was a one shot deal.
I'll just seal it up and hope for the best.
Rocky_Road
The label on my new tube of 5200...said the same thing!
But...it also says that it will last longer if stored in a cool, and dry, place.
Mine will sit behind the mustard...in the door of the refrigerator! :D
eli_lilly
I store mine in the fridge.
-E
n2ostroker
I have a tube of fast cure 5200 and reg 5200. Both have the same warning. The fast cure I have used 3-4 times now and just reopened it the other day. After digging thru the hard stuff it was fine. I picked mine up at lowes on clearance for $2.95 a tube. I'm sure next they'll cost a little more....
Yacht Dr.
Just a couple suggestions on cured tipped tubes ..
1. Drill the hard stuff out of the tip.
2. I have several tubes in the draw that I have poked or sliced little holes ( starting in the back ) and squeezed out. You can use a stir stick or just poke your screws into it for use.
Yd.
sschefer
I buy it in the caulking tube style. I just let the pressure off the handle and stick a nail in the squirter end. I just pulled one out and used it last night. I last used it at least a month ago. 2 handle squeezes, a pop and then squirt. No problem.
