1965 johnson starting question
stevensmithnc
The motor has a big wiring harness running to a metal control box and also some wires branch off to an ignition switch with a key. The control box is a mess and rusted pretty bad....... What do i really need to get this motor running as far as wiring goes.(when i say control box i dont mean the throttle control box, i have that as well and its all connected and hooked up.
Homedad
Re: 1965 johnson starting question
I'm assuming your talking about the box with the solenoid in it. Your battery and ignition switch are connected to this. If it is rusted and or corroded try cleaning the posts and connectors. The solenoid may need to be replaced depending on the corrosion and rust. Remember what wires go where when disconnecting the box.
samo_ott
What HP and model? If it's a 40 it might look like this.
