whats to hot
wideide
so after over heating and i sanded down cillined walls shaved head replaced therastat good impeller. had to pull the fly wheel because everything under it was loose retitend with lock tite. took it out for a test run it ran better then ever before but the pee streem is weeker and more water come out of exoust then before the water from the streem is warm when before it was cool with acational warmth in it motor was hot to touch ran for about an hour it didnt overheat but i didnt push it past half throtle would like to know temp range then check with temp tester. its a 1976 35 johnson 35r76g thaks for looking
bagnallt
Re: whats to hot
I read this question with interest... I dont mean to hijack the question.
but does the 140-160 is that the operating temp or if it gets to 140 its too hot?? I have a 30 Johnson with no alarm was going to check with a thermometer.......
Also.... forgive me for the stupidity but is that 140-160f or centigrade.. ( being from the UK ... now living in Fl... and used to using degrees centigrade I was wondering)
TONY
bagnallt
Re: whats to hot
Thanks for your help Will now convert to F .... Or try too.. LOL
kenmyfam
Re: whats to hot
140 to 160 degrees f is your normal operating temperature.
Don't worry, I am a limey as well. Been in Canada for 20 years.
