jhamill1986
- Joined
- May 19, 2009
- 10
60hp 83' Mariner 60e 6F0 L 305764. I'm a newb to the outboard world so bear with me. after about 30 seconds at WOT the engine starts reving up and down sporadically and then dies if you bring it back to idle. Usually have to run mid-throttle to get back to the ramp before it dies all together. also i hear some faint knocking whenever i have to limp it back to the ramp but dont hear it when its on plane. Problem just started during 5th time out on the water since the carb rebuild (i had no problems prior except for plugs fouling and idle adjustment) but it has always started back up after sitting for a while. now it wont start at all...even on the muffs... During this time i did a spark plug test and each plug is throwing a very strong spark. The motor sat up for ten years and i have rebuilt the carbs, cleaned out gas tank, replaced bulb and hose going to the gas tank, changed spark plugs, changed lower gear oil and impeller and ran seafoam through it. The problem just started with it reving up and down like that...the only problem i had previously to this was the plugs fouling every ten minutes due to excess carbon which i have recently fixed with a can of quicksilver engine cleaner. Maybe this has something to do with it (dont remember exactly what its called but it certainly cleaned my engine and made it run a lot better in the water at idle and mid throttle speed - plugs stay very clean now and engine goes into gear very easy at the lowest idle setting) oh and pumping the bulb does not affect idle speed nor does it help when the engine is going crazy at WOT. Ive read a lot on this site and cant quite find anything similar to what my engine is doing. I'm thinking something electrical. any help is appreciated!
Thanks,
Joseph
Thanks,
Joseph
