Mercruiser 165 Front Main Seal Leaking...
johnsland8
I have a leak from the front of my engine, I believe it's from the front main seal, although I haven't fully investigated... I have to remove the rear seat to get a good look at it.
Just wondering if it's possible that an improperly aligned outdrive could have an impact on this leak?
Thanks!
johnsland8
Re: Mercruiser 165 Front Main Seal Leaking...
Cool thanks bruce...
I had just done some work to the outdrive and had it removed. Before I replaced the seal I wanted to make sure I wasn't going to have the same avoidable problem again...
Tool looks slick...
I just used that tool removing the main seal and cam seals from my Lexus. Works awesome when you are removing a seal that is still around its shaft.
rockyman
before you go tearing it down make sure your oil filter gasket is not leaking , if its a L6 merc
johnsland8
Will do...
And yes, sorry, it's the inline 6.
Bt Doctur
Or the timing cover didnt rot thru
