3.0 manifold water leak
soxfan55
all right ready to get my feet wet.
3.0 merc I/O didn't quite winterize right (you big dummy). started up fine, but water pouring out under manifold the whole length. and i mean pouring.
no water in the oil yet. guess i'll have to take manifold off. any qiuck ideas as to what it could be ? i won't get to take off the manifold till next week. thanks in advance. dan:confused:
rbh
Re: 3.0 manifold water leak
If your lucky you popped a frost plug if your not lucky you have a crack in the block or the manifold or both. now you have to make a decision replace the manifold (thats fairly cheap and easy) and try and fix the block or replace?
I hope your feeling lucky!
rob
Ayuh,... If you're Lucky, it's Just the Manifold itself...
JustJason
nahhhh.... if its right up under the manifold... then you cracked your block. That's were 3.0's crack is right there up high.
Either use a mirror, or pull the manifold and you'll see.
soxfan55
Just took manifold off and block has a 4" crack (gash) between the frezze plugs up high 3" from the top. Anyone know if someone has used jb weld on a crack that size ?
Bt Doctur
At this point it can`t hurt. drill each end with a 1/8 inch bit, vee out the cracked area with a grinder or dremel, wash the area with acetone, apply the JB ,and let us know .
soxfan55
crack was bigger than i thought about 10 inches. i drilled 1/8 hole at each end applied 2 sets of JBweld let sit 24 hrs. put it back together with new gaskets. ran it 1/2 hr with muffs no visable leaks and temp stayed nice and cool, next test this weekend on the water under a load. will try to upload pics. wish me luck thx dan
