I have about a 2005 Sea-Ray with 150 hours, SN 0W324202, Mercruiser 5.0L. When starting engine it will crank, fire, and immediately die. Only way to get it running is put it in Neutral at about 1000RPM and start. As soon as you go to idle it dies. I have a soft alarm for check engine with the 2 beeps every minutes. I pulled the foam out of the IAC, no difference. The water pressure was about 1 psi at 800 rpm or so and got to about 3 psi around 2600. Oil, temp all normal. Tomorrow I will get the codes pulled but does anyone have ideas for now?
-Dave
-Dave
