Trying to set up two battery system
No show
I have an 86 Celebrity 210 Cutty.Does anyone have some kind of diagram of how it should be hooked up. I needto go from one batter to two.
Thank you:)
Phantom_II
Re: Trying to set up two battery system
It pretty much depends on what you're trying to accomplish with two batteries.
Are you trying to get 24 volts (connect in series) ?
Are you trying to increase the amp-hour capacity (connect in parallel) ?
Are you wanting a reserve battery (use a perko type switch) ?
Are you wanting a separate battery for accessories and/or a trolling motor (get a dual battery isolator) ?
No show
I guess seperate batteries
flargin
look at the stickies on top of this section. they have a number of different options.
There are a couple of great diagrams throughout the threads, might want to search and you will find a lot. Take a look and then if you need to figure out how to install it for your situation, we are happy to help.
