1996 70 HP evinrude reverse problems
jimogeek
Damn. I've got a problem with my reverse now...
1. The reverse has been 'grinding' a bit for a long time. Nothing too dramatic, but you can hear it when it goes in. A second and a half period of minor grindage
2. Last night wanted to go out for a spin, the boat wouldn't go into reverse. No noise, just acted like you didn't engage reverse
3. Tried asjusting the adjuster to the max, nothing doing.
4. Disconnected the linkage, tried to manually force it into reverse with the motor running, nearly broke my thumb (bounced a bunch and it smarted)
5. Shut off the motor, put it into reverse and started the motor, reverse was engaged
Can someone lead me down a path? I'm afraid I've worn out the gear that kicks it in, how can I tell? I do have a manual, just haven't dug it out yet.
help!
Re: 1996 70 HP evinrude reverse problems
had the lower unit been off, just prior to it starting this grinding?
jimogeek
Hmmmm... It's been doing it for a few years, the lower end has been off about every other season to do the water pump but I've never noticed it having an effect on anything.
jtexas
is the gearbox making metal?
jimogeek
not sure. I'm going to try and get the boat out of the water and into the backyard today or tomorrow. It's down at my dock right now.
