Mike_krab14
Thread starter- Joined
- Jun 19, 2009
- 2
Hello I have a 69' 55hp evinrude... When im using the boat....it runs great for a little while then It starts to miss like crazy and eventually quits...if you let it cool for 1/2 hour or so it runs again great and repeats itself and then starts missing and then dies.. I change the powerpack... i changed the coil.... i check wiring.... battery is right up,...could this be a faulty condensor because ive clean the points as well......sometimes i get longer use out of it then others.... but i find the more load the faster it quits.... like when i have a skier or even just 4 people onboard... And im pretty sure i have proper fuel supply as well or it would run this way hot or cold......
Thanks...
Mike
Thanks...
Mike
