brianzarna
Thread starter- Joined
- Jun 19, 2009
- 4
Hello,
I have a 1963 Sea King 5 hp tiller motor. I just got it a few weeks ago. Put in new 24:1 fuel mix and it ran AWESOME on three different trips.
Yesterday it stalled on me then wouldn't start. The pull cord was REAL HARD to pull. There was a decent size oil slick in the water.
I took it out of the water. I removed the spark plugs. They look good. I sprayed WD40 in the plugs and now I am able to turn the flywheel by hand and with the pull cord but it is still pretty hard.
I noticed oil dripping (I thought from the prop) but it was actually from a very small hole directly over the prop. It almost looks like this hole was drilled (about 1/32" dia.). The WD40 that I sprayed in the spark plugs made its way down to this hole and dripped out.
I unscrewed the lower unit oil screws and drained the "oil". About 2 cups of water came rushing out followed by 2 tablespoons full of grey/brown sludge. I blew out the lower unit oil with an air compressor...
That's where I'm at. Any ideas if I may have damaged it beyond repair? Any suggestions?
THANKS A TON!
Brian
THANKS A TON!
Brian
