jlinder
Thread starter- Joined
- Jul 5, 2004
- 1,086
After some problems this season got the engine running but now I have a leak from the exhaust manifold. I guess it is time for replacement but I wanted to make sure I have all my ducks in a row before I start the job.
Specifics: 1988 OMC Cobra stern drive w/ 5.0L GM V-8 engine
1. A little unclear on the water path. From what I can see the water runs through the exhaust manifold then through a hose into the engine but I see only one hose. There is a place for a hose on the bottom of the manifold but that is capped off on both manifolds. What am I missing?
2. I guess I should check both sides and maybe replace both sides on the assumption that if one is bad both are worn out/rusted out. Right?
3. Any tricks or gotchas I should be aware of? I would hate to pull the manifold to learn that I am missing a part and have to wait until it comes. For example there is the rubber cap on the bottom of the manifold. Should this be replaced? What about a gasket kit for the elbow? Any gaskets I don't know about, etc.
4. Again, what about tricks or tips? Any tips to make it easier or "whatever you do make sure to...." notes?
Thanks
BTW - it took a while but I found the manifold here at iboats. Good price it appears. Love to support those who provide this forum.
Thanks
