Re: prop + more hp = more speed @ same rpm?
If you have a real 1.5:1 gear ratio then the prop slip you are showing is astronomical, as it is over 45%. I have never seen REAL prop slip that high and yet still stay within the recommended WOT RPM range, I find that inconceivable. The motor must be fine as it theoretically turns almost the same RPM with both props, even though there is a 4" pitch difference. That leaves me totally baffled. I find that
if your boat weighs about 2,300 pounds, which I believe is the maximum it can weigh with 2 people, 6 gallons of gas and some drinks plus base boat weight of 1,800 pounds, and a gear ratio of 1.5:1 with a 175 HP engine you should be able to do at least 40 MPH with a
16" Pitch Prop, not a 23" Pitch.
Check your tachometer, something is NOT right. I am just absolutely baffled and making wild guesses here because it just doesn't make sense, I will tell you that you should be using right at a 16" pitch prop in aluminum for that boat and motor combination if your gear ratio is 1.5:1, my program is always spot on for prop pitch with a single engine but it is not always right on speed because of all the variables involved with hull form and where the weight is placed in the boat as well as other variables. Here are my numbers for your boat with a 1.5:1 gear ratio and a weight of about 2,300 pounds.
I will tell you I have a 16' flats boat with a 40 HP outboard and I get about 30 MPH out of it with an allup weight of approximately 1,800 pounds. In comparison your boat should fly. I am sorry I don't have a better answer.
Boat and Motor Info
Prop Picker
Prop Slip
If you would take the boat out and run it this weekend, with the hydrofoil OFF, and use both props and give me the RPM and speed for both of them from 3,000 RPM up to WOT in 250 RPM increments I am sure we can figure this out and find the problem. I will take those numbers and run motor and prop thrust calculations as well as prop slip and motor power available versus prop power required.
Is there a possibilty you are running the wrong diameter props, it just doesn't make logical sense.
H
