Re: Maximum RPM's for 92 Evinrude 90hp
Dhadley,
Reason I was thinking it might need a lower pitch prop, it just doesn't seem to have the power to get on plane. The boat is a 17' aluminum deep/wide Sylvan, has a 8hp kicker on back if that makes a difference for weight. The odd thing is when I go over another boats wake it seems to lose power, if you make sharp turns it sometimes picks up rpm's and takes off. If I have four people in the boat there is no way it will plane out, with two people, one has to be up front to plane. Sometimes it runs great, 38mph it's at 4800rpm's. I recently bought this boat so I don't know the history of it. What I have done so far is: new plugs and wires, had a spark test done and that was good. Compression is 125lbs in all cylinders. Drained built in gas take of old gas, changes fuel filter, rebuilt carbs. I also tried another gas tank and hose thinking that may be the problem. You mentioned to verify the tach, how is that done? Don't know what else to try, as it seems to be an intermittent problem. Had it to a certified marine mechanic and he's not sure what it could be. Would a fuel pump or CDI box cause this.
