spencerhmoore
- Joined
- Jun 20, 2009
- 4
I just bought this engine. Initially, it would start, rev up to pretty high RPMs, then lose RPMs and die. I disassembled, cleaned and rebuilt both carbs. Compression is 140 top, 150 bottom.
After the carb rebuild it wouldn't start at all. Turns over fine, puts smoke out the back, shooting water out strongly, just won't start. After I did the compression test it started with the same symptoms as before the rebuild, then died. Won't start again unless I remove plugs and turn over briefly. When I put the plugs back in it'll do the same thing.
Plugs are pretty clean. When I take them out they are wet.
Ideas on how to proceed?
