Wont take throttle
123trentm
I am having a problem with a 1976 77hp evinrude. 9 out of 10 times when I give it throttle it falls on its face and dies. Once in a while it takes it and runs great:confused: I have rebuilt carbs, new fuel pump, new fuel lines and primer bulb. Any suggestions would be appreciated.
bankerjohn
Re: Wont take throttle
Have you checked the spark and compression on each cylinder? If those are OK, I'd suspect a clogged up high speed orifice (even if you've rebuilt the carbs) ... or the fuel pump.
outlaw241
check nozzle gasket's to make sure they are in good shape,could be sucking air an not fuel above the float
