Plug Gap Question
Boss Hawg
Thanks to a lot of great guys around here i've got my 1987 70hp Johnson running great :D One thing tho, I put Champion plugs in & gapped to .030 & when i troll around or just cruise at planing speed & then set more than 30 minutes or so it's a bit hard to crank:( Meaning instead of the normal "key touch" I need to prime & even sometimes use the high idle lever to get'er going- I'm thinking if i gap to .035 it might help keep the plugs from fouling at the lower speeds but wanted some more experienced opinions before i take it back out this weekend :)
Appreciate input :D
JB
Re: Plug Gap Question
There was a time when OMC said to use a .040" gap. I see no harm in .035".
kenmyfam
You won't know in reality till you try it. Should be fine in my opinion.
