ammermanfam
Thread starter- Joined
- Jun 22, 2009
- 50
Hello my name is John and I am new to the board. I jave an 1985 85 force that was running fine till I changed the primer bulb. First trip out as soon as I got on plane the engine would die. I reprimered the engine and it fired right up. Kept happenin for 10 minutes then ran fine the rest of the day. A few trips later I noticed the fuel lines between the carbs were wet with gas so changed them. Now the problem is back . I changed the diaphram. Yesterday on the water it would Idle along just fine. When I tried to get on plane it would bog down and die. I tried having my buddy hold the steering wheel while I would squeeze the bulb and the boat would stay running strong. It even ran fine most of the day after that. On way back to the ramp I noticed every time the nose dived after hitting a wake the motor would pause for a split second. Just wondering which direction to go from here? I alao end up with a little fresh fuel on the outside of the bowls and intake. Could this strictly be a stuck or sticking float Issue??? Thank you in advance JOHN
