I just bought an older mercruiser (ford 302). On first trip out it died after about 20min. After some testing I narrowed the problem down to no spark from the coil. After a tow back to the launch, I replaced the coil (generic coil from autozone). Next time out it ran fine for about 30min, until I idled back. It died and would not start. The coil was slightly warm (~150F), so I pulled it off and dipped the sealed end into the water. Put it back together and it ran fine (at least back to the launch). Any thoughts of what to check before the next outing? Would the coil be over heating? It has the in-wire resistor, when I tested w/ key on it was ~9v. With motor idling I found ~11v at + terminal. Any advice appreciated!
