WindInDaFace
Thread starter- Joined
- Jun 23, 2009
- 2
Hi all,
I noticed a couple of things this past weekend that didn't seem right on my in-laws 18' glastron ski boat (mercruiser I/O). After scouring other posts here I think I found the answer to one of the issues (faulty neutral safety switch) which was why sometimes the boat would appear to have no battery juice when the throttle only button was pressed and the key is turned to start the motor. Although, I'm not sure that is exactly the issue since it occurs sometimes when the throttle only is disengaged and the key is turned. This makes me think it might be a wiring or ignition switch issue.
The other issue is that the control arm itself is hard to engage into gear (forward or reverse) and even after the transmission is successfully in forward or reverse, the control arm seems overly tight and difficult to advance. I was hoping this might just be lack of lubrication somewhere or some type of tension adjustment in the throttle arm?
Thanks in advance!!
Thanks in advance!!
