I use my boat most weekends and after each use I would pull the fuel lines on the two Johnson 70hp 1977ish motors and run them out of gas with the logic being that fuel sitting in the carbs for a week or two is bad. After I lost one engine, I installed a replacement (with this forum's help btw, thanks!) and my local mechanic told me that as long as I use a fuel stabilizer, I can keep fuel in the motors in between uses. His thought was to reduce wear by not starting the motors without oil/fuel for this first few turns especially when those rings have been sitting in the cast iron block for a week, rusting away. His theory was that this was the reason I lost compression on the scrapped motor's number 2 cylinder.
I live in California and my boat lives in the water so the most I ever go without using the boat is maybe a month.
What are your thoughts, with or without fuel?
